No signal at Fuzz Face Q1 collector
Started by m7b52000, May 27, 2020, 09:06:20 PM
m7b52000
Am building another standard pnp Ge FF. While debugging with the audio probe I ser that yhrte is audio at q1 base but not collector. Soldering seems ok  and problem exists with another transistor. Is this a case  of signal escaping to ground or transistor not turning on? Anything else I should be chasing?
Cheers
m7b52000
Yes, 2.2 V at base, 2.9 V at collector. Both high....
antonis
Probably Q1 Emitter isn't grounded or is "open"..
What are the voltages on Q2..??
P.S.
In presume you intentionally omited minus (-) sign in front of measurements taken..
m7b52000
Quote from: antonis on May 28, 2020, 08:08:19 AM
P.S.
will check all tonight but as I recall Q2 collector was about 4v. Yes all voltages neg :)
