A little help with the Hot wired
Started by whomeno, August 29, 2020, 01:38:46 PM
whomeno
ok built a hot wired from here http://tagboardeffects.blogspot.com/2017/11/wampler-hot-wired-v1.html
Ch1 works great, ch 2 is where the problem is, it has a weird distortion to it. hard to explain.
used a jrc 4580DD using 9v the readings on 5-6-7 don't seem right to me.have reflowed the solder checked for bridges and rechecked all hookups
1 4.55
2 4.54
3 4.1
4 0
5 0.46
6 8.33
7 8.50
8 9.0
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
antonis
Check voltage on right 1M resistor upper leg..
whomeno
Gear as of now
And a lot of pedals
antonis
If so,  check continuity between lower leg and pin 5..
whomeno
ok got continuity between lower leg and pin 5.
Gear as of now
And a lot of pedals
antonis
Then you should measure 4.48V on pin 5..
(unless there is some light short between pins 4 & 5..)
Power off, take off IC and measure continuity between pins 4 & 5..
whomeno
yes i got continuity between pins 4 & 5..36.k
I don't see any thing between pins 4 and 5 at all
Gear as of now
And a lot of pedals
whomeno
I re cut on both sides of all ground traces. still the same
Gear as of now
And a lot of pedals
whomeno
re built the board, all is ok now Thanks
Gear as of now
And a lot of pedals
antonis
