AC128 paired with AC176 for fuzz?
Started by jm22, June 15, 2020, 07:32:08 PM
jm22
I've been thinking about using the AC128 for my first fuzz pedal, a fuzz face clone. This transistor model jumped out at me as fairly ubiquitous and still readily available from multiple sources.
In any event, I stumbled onto this ebay listing for an AC128 paired with an AC176. The seller says this pair is for fuzz, but the AC128 is a PNP and the AC176 is an NPN. I thought one must have a pair of PNP (or conversely a pair of NPN) for a fuzz. What am I missing here?
https://www.ebay.ca/itm/FACTORY-MATCHED-PAIR-TUNGSRAM-AC128-K-AC176-K-NOS-GERMANIUM-TRANSISTORS-FUZZ/132994574800?hash=item1ef71829d0:g:l~kAAOSw18Bccr9u
willienillie
Factory matched.  Tungsram wasn't thinking about fuzz pedals.
jm22
Thanks for the reply. Indeed, Tungsram wasn't thinking about fuzz pedals, but the seller of these NOS transistors certainly is, and he says he's sold 100's over the years. I am trying to understand if one can indeed use one NPN and one PNP in a pedal, say a Fuzz Face, and if so, what advantage might it have, and what changes must be made to the circuit topology to accommodate both an NPN and a PNP.
idy
Complimentary pair 2 transistor fuzzes... Roger Mayer Axis... what else? That was silicon.
You CAN use complementary. But for 30 years PNP Ge was much cheaper than NPN Ge. (Conversely, for a decade NPN Si was a dime cheaper than PNP Si.) The fuzz market is CHEAP.
I was looking for Ge complements for a non-fuzz application. But for most of Ge's reign, that was very rare. Maybe one NPN as a power stage driver.
buy two of the posted pairs, build two two transistor circuits, one pnp paired, the other npn paired. buy three sets, build two tonebenders ..... can't guarantee the hFE/leak figures, tho. suck 'em and see.
" I will say no more "
mac
There are a number of projects out there for npn-pnp, Si or Ge.
For example Sixties 60s Style Fuzz Box.
Also, Jordan Bosstone, Heathkit TA28, Harmonic Percolator, Arsenio Novo's, can be tweaked to use only Germs. I did this, sounds great, but temperature is a problem with some of this circuits.
What about a small guitar amp?
mac
