Tube diode bridge clipping stage
Started by Banjan73, June 29, 2020, 01:06:53 PM
Banjan73
Hi!
I just was thinking, its normal practice to use SS diodes in a clipping stage. Does anyone know if someone, sometime have made a tube diode bridge clipping stage?
That should work right, or not? If not, why?
mozz
Seems like it would be easy enough to implement in a tube amp if it worked.
Groovenut
Quote from: Banjan73 on June 29, 2020, 01:06:53 PM
Hi!
Yes some of the prominent amp companies have done so. One notable is Fender's Performer 1000. It uses an all solid state design with a 12AX7 wired as a 2 diodes.
You need to set up the heater voltage, plus a positive and negative bias voltage for the anode and cathode. The bias voltage sets the clipping for the tube diode. I have only seen them used in anti-parallel.
You've got to love obsolete technology.....
Merlin's Spark Gap uses two EB91 diodes for clipping in an otherwise TS-like overdrive.
Banjan73
Cool.
I thought I had a revolutionary idea here, but I guess there is nothing new under the sun ;D ;D
Banjan73
That spark gap was absolutely supernice!!
mozz
There are lot of triodes that have 1 or 2 diodes in the package, don't know if they are usable as they may have a common anode.
The 6BN8 has a triode and two diodes with all electrodes independent of each other.  The triode has a ยต of 70 so it is equivalent to the triode in a 6AT6 in that respect but has higher transconductance and lower plate resistance than a 6AT6 triode.
BTW, ignore what I said about the Spark Gap being "TS-like".  That's my appalling memory talking.  :icon_rolleyes:  It's a pair of opamp clipping sections that you might find in lots of circuits (in many variations), one of which may or may not be a TS.  Back to bed...
Marcos - Munky
Just something to add. For a 12AX7, you need 150mA@12V (or 300mA@6V) just for the tube heaters. A single TS-like circuit draws about 7mA@12V, so a single TS-like circuit with 12AX7 as clipping diodes draws as much current as about 22 solid state TS-like circuit. Also, there's the huge price difference between a 12AX7 and a pair of 1N4148.
A tube as clipping diodes may sound good? Probably. May sound different than a regular diode clipping? Don't know. It worths the extra current and price? Well, it depends on the answer of the last question. But imo there are better uses for a tube.
