I’m sure you guys are hip to this ...
Started by DarkHorse, June 30, 2020, 01:05:59 AM
DarkHorse
...but this tester is dirt cheap, pretty darn accurate, and super handy ! I got it off eBay for like $20-25 or so. It tests transistors, caps, resistors, Diodes, etc....
A VERY handy companion to a multimeter, and extremely useful !
willienillie
antonis
Marcos - Munky
Yep, it's a nice tool. Cheap, can measure lots of stuff, shows transistors pinout, blinks leds so you can check their colors, some of them measures ge transistors leakage (mine doesn't :'().
The only thing to be aware is the battery. It starts to be innacurate with a not so big battery voltage drop. Not a big deal for stompbox buildings, but once I had trouble measuring a very low value resistor (less than 1r). A fresh battery solved the problem.
MaxPower
Got a cheap careless version primarily for the pf cap range. Not reliable with jfets though (d and s pinouts often wrong). Haven't tried mosfets yet.
What lies behind us and what lies before us are tiny matters, compared to what lies within us - Emerson
anotherjim
Quote from: MaxPower on June 30, 2020, 11:05:51 AM
You can swap D & S on most JFET's without any ill effect  - still works. So, you can imagine the test box is not going to be able to tell you if they're wrong ways about.
duckduckgoose
I got one that I think is based on the same software but it's a black and white screen with a green backlight. clear acrylic case. i think it was only 8 dollars on amazon lol
Marcos - Munky
#7
Quote from: duckduckgoose on June 30, 2020, 03:12:35 PM
This is the exact one I have.
https://pt.aliexpress.com/item/32810272625.html
Probably there are cheaper ones, I just copied the first link I came across. The keyword to find them is mega328.
DarkHorse
Quote from: antonis on June 30, 2020, 05:06:58 AM
Quote from: DarkHorse on June 30, 2020, 01:05:59 AM
Compared with..???
Comparing not only to my MM, but also using it to measure known value parts to check accuracy.
Electron Tornado
I think I posted this, but here it is again:
Compared with..???
I have one of these as well as one of those pictured in the first post. I set up R.G. Keen's method for testing transistor gain on a breadboard and tested a bunch of germanium transistors*, then compared the gains given by both of those testers. The results were very close, with the largest difference being about 6%.
The one in the video is fussy about battery power, while the one in the first post has a rechargeable 5V battery.
*A couple of Russian GM28 and a bunch of AC176.
"Corn meal, gun powder, ham hocks, and guitar strings"
Who is John Galt?
