Splitting and isolating a signal
Started by mark2, June 27, 2020, 10:17:49 PM
mark2
Thanks for the extra info!
If I'm learning/understanding this correctly, that might shed a lot of light on this.
If the l7805 impedance is 0.2 ohms a 680uF cap should give a cutoff of about 1200 Hz.
So perhaps I can add a resistor and use a much smaller cap and get the same noise reduction. I'll give it a try unless I learn this is totally flawed.
It still doesn't solve my issue, but it helps a bit. This project is probably dead in the water from the noise, but I'm not quite ready to give up.
antonis
IF noise comes from mains rectification (100-120 Hz) the LPF have to be placed before 5V regulator..
(Both for "to the point" issue remediation and convenient voltage drop across the filter resistor before 5V regulator output..)
mark2
I discovered the power noise, and it's not from the OLED.
I came back to this today and found that it was whisper quiet with an attiny85 and its own supply.  The noise was only introduced when I was using an arduino board powered by my computer via USB. And even then, it was only when my keyboard+mouse usb switcher, or HDMI monitor were plugged in. Each of those two adds considerable noise.
