Switchy Thing
Started by moosapotamus, July 27, 2020, 09:08:25 PM
GGBB
That looks better. But you've lost the fx-in grounding on bypass, which therefore is almost the same as
Quote from: RickL on July 28, 2020, 09:41:45 PM
Check this thread out. https://www.diystompboxes.com/smfforum/index.php?topic=120969.msg1135205#msg1135205  Two switches, the momentary gives you the opposite of what the standard switch gives you.
which is
No need for the extra complexity, parts, and cost of the logic as the LED can be wired directly to the 4PDT. It doesn't toggle the LED with the momentary switch, but that's not very useful since you obviously know when you are using the momentary switch.
