2333 Hz whine on breadboarded Bluesbreaker—what might cause it?
Started by Buran1997, September 01, 2020, 01:57:21 PM
Buran1997
I recently breadboarded a Marshall Bluesbreaker. I've run the circuit off of a 9V battery with no issues, but when I tried running it from a 9V DC wall wart, I noticed a quiet whine. I used a sine wave generator to match the frequency, and I think that the whine is about 2333 Hz. Adjusting the potentiometers (including turning the volume down to zero) doesn't affect the noise at all, so I suspect that it's coming from ground instead of the circuit. I've run other pedals that I've built off of the same wall wart with no issues, so I wonder if it might be an interaction specifically between the wall wart and the breadboard, but I want to make sure that this issue won't persist when I build the circuit on perfboard.
Has anyone else encountered a similar issue? Is this likely to persist once the circuit is built and boxed?
willienillie
If it's quiet with a battery, the noise is coming from the wall wart.  SMPS, has a high-pitched whine.  Some pedals filter the noise out better than others.  You can add filtering to your Bluesbreaker to help combat power supply noise.  A small series resistor (47~100 ohms) at 9VDC in, followed by a large-ish electrlolytic cap (47~100µF) to ground with a 100n ceramic in parallel, should do very well.  A quieter wall wart, intended for audio/pedal use, would be a good thing too.
GGBB
Quote from: Buran1997 on September 01, 2020, 01:57:21 PM
Possibly, but probably not. You can test with aluminum foil and/or a pie/cake pan - any metal "box" like thing (grounded).
