Transistors wrong voltage little help
Started by whomeno, September 09, 2020, 10:17:30 AM
whomeno
ok, nyc big muff. transistor voltages off. what am i missing? I checked all the normal stuff I can think of.
BC 550's
Q1
E  .0 v
B  .56 v
C  8.25 v
Q2
E  .00 v
B  .56 v
C  8.21 v
Q3
E  0 v
B  .56 v
C  8.22 v
Q4
E  .15 v
B  .71 v
C  8.42 v
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
whomeno
#2
you are right i had the pins mixed up. a lot of the time the diagram don't match the pin out.
Thank you
Gear as of now
And a lot of pedals
antonis
Almost 8V reverse B-E bias shouldn't be considered favorable for long heaslthy life of BC550, should it..??  :icon_wink:
Quotea lot of the time the diagram don't match the pin out.
There's three versions and often you can guess what it is from the part number.
[click for bigger version]
I was going to say this in words but some nice person has already drawn-up a pic.
antonis
willienillie
Quote from: Rob Strand on September 09, 2020, 07:08:06 PM
There are always exceptions.  2N2925 (USA - Thomas Organ wah transistor) is ECB, I suspect others in that series are also.
Marcos - Munky
Usually, it's a great idea to check the datasheet/pinout, or read the comments/build reports to see if there are anything on reverse transistors. Unless you draw the layout by yourself using a trustable software/library, like Eagle + MadBean library.
Last but not least important, how's the volume on this one? And did you liked how it sounds?
QuoteThere are always exceptions.
Sure.   The datasheet is always best but for a quick check that pic will cover a heap of cases.
IIRC when BC548 etc. first came out you could get them in non-European pin-outs,  they weren't in production long.
