Joyo Ultimate Drive Tonesucking
Started by niektb, July 02, 2020, 07:38:32 AM
niektb
Hey all, I'm rearranging some stuff on my pedalboard but the Joyo Ultimate Drive is giving me troubles! Right now it sits just in front of the multi-effect that I use (Line6 M5). i've set the M5 to true bypass mode just to make sure it doesn't affect my drive sound. However, whenever I bypass the Line6, the volume drops tremendously and the treble is affected as well. So I'm guessing I have a tonesucking problem, the cause being the poor drive capability of the Joyo. I've tried it with a different reverb pedal (also true-bypass) with the same results...
So the question of course is... How do I fix it in the most easy way?  :icon_mrgreen:
I have a slightly modded joyo, here is the schematic :)
antonis
Depending on what impedance JOYO OUT drives, I'd lower R11/R12 Values by a factor of 10..
(C10/Tone pot value should need re-arrangement but it should be easy to obtain..)
j_flanders
niektb
im fully aware thay a buffer would fix my issue (that seems to be the solution suggested most along with lowering the value of the volume pot (which I already did)) but that's not what I m after since i have more unbuffered pedals (and they work fine). So I'm looking for a schematic fix (and lowering these 22k and 33k seems a very good option, thanks!)
but I have not found a solution on the internet that also gives the values for the tone control
alexradium
i tell you what i did to this same pedal,i rewired the buffer in front of the circuit to the output,using a NPN transistor instead of the fet,and making it a true bypass,it is a bit of work but in the end you get something that works.
niektb
Quote from: antonis on July 02, 2020, 09:15:29 AM
I tried this suggestion and it definitely boosts volume and brightens (both of which are good things IMO) at the expense of the switch which isn't doing a lot anymore but the buffer issue is definitely still there. Simulation confirms that there is quite a bit of volume difference...
How much lower can I make the volume pot?
Steben
Quote from: niektb on August 13, 2020, 12:11:01 PM
After the buffer lots!
Steben
What, lowering resistors?  :icon_mrgreen:
antonis
niektb
Pot took a while to be deliveder but it's finally in! This is what I ended up doing:
Lowering those 33k and 22k resistors with a factor 10 definitely brightens the pedal up, but that's not a bad thing IMO as it was quite dark before :)
