Veroboard Timmy switch question.
Started by StevenJM, October 04, 2020, 01:35:37 PM
StevenJM
I haven't posted on here in a few years, but thanks to google and lurking, you guys have helped more than you know haha.
Anyways... I'm a bit stumped on this one. Can someone tell me where the mini toggle switch gets soldered to? If I connect it directly to the lugs of drive 1 & drive 3, the switch works, but my drive knob has zero effect (which makes sense if 1 & 3 are connected). But if I just disconnect the switch, then my drive knob works just fine. (Luckily for me, this is the setting I prefer anyways, but I'd still like to know what I'm doing wrong).
Thanks in advance for any help or tips!
antonis
Is your particular switch a on-OFF-on one..??
StevenJM
Quote from: antonis on October 04, 2020, 02:11:23 PM
That is what I ordered... but that doesn't always mean that's what I received.
StevenJM
Just opened it up and checked... it is on/off/on.
RickL
Does the drive control work in the middle (off) position of the switch?
StevenJM
Quote from: RickL on October 04, 2020, 03:40:13 PM
No... even in the off position the drive knob doesn't work... which makes me think my switch is mislabeled or malfunctioning and is the issue.
StevenJM
I ran a continuity tester through the switch and it tested right... soldered it back in and now it's working... 🤷‍♂️
