Supplier for Large Color Fluted MXR Style Knobs 23mm other than BYOC
Started by natezaps, October 17, 2020, 04:45:41 PM
natezaps
Does anybody know where to get these knobs other than BYOC?
I'm looking for large color fluted mxr style knobs that measure 23mm in diameter. Specifically red, green, and yellow.
I'm aware of the large 25mm knobs that have rounded flutes - I'm not looking for these. I have them right now and they are too big.
This is what I'm looking for:
https://buildyourownclone.com/collections/knobs/products/large-fluted-style-knob-black
The only reason I'm trying to find another place is because BYOC charges a lot for shipping
blackieNYC
natezaps
Quote from: blackieNYC on October 17, 2020, 06:14:52 PM
Try smallbear electronics?
Small Bear carries the 25mm ones. (and also the medium size ones) the 25mm ones are too big for what I need. I ordered some that size some time ago. they cause the top of the text label for the control to be cut off. the medium size (19mm/20mm) is too small. they look stupid on the pedal. this is why I'm specifically looking for the 23mm. It's also the size that came on the pedal originally. thanks for your reply though.
willienillie
Small Bear has the right size but only in black:
http://smallbear-electronics.mybigcommerce.com/black-fluted/
Tayda and Lovemyswitches don't have the right size.  Small Bear says it's an Eagle Plastics part, maybe that will help track down more.  I didn't see any at Mouser.
