Civil War Big Muff fuzz problems
Started by OiMcCoy, March 01, 2021, 02:40:08 PM
OiMcCoy
Oh I am all for the silliness.
I will for sure try that. I am also going to play with the diodes. Thinking LEDs might give me the bite I am looking for. Right now its very creamy. Especially with the mid controls.
Fancy Lime
#21
Yeah, uhm, sorry 'bout that! Lesson: check your spelling, there's some real dill weeds on the loose :icon_wink:
On a more serious note: try also to use different caps on the diodes in the two stages. For example a smaller cap with Si diodes in the first stage and a large cap with LEDs in the second. This let's you fine-tune the low-frequency clipping and overall low end. Lots of fun to be had with experimenting here.
Cheers,
Andy
Phend
Cool,
Quote. I am also going to play with the diodes
  • SUPPORTER+
Do you know what you're doing?
OiMcCoy
So I have had the chance to play around with it some more. Right now I am extremely pleased with it. The only issue I have is that the low end can get a little farty on my bass. But that's not exactly unexpected. I am going to keep playing with some different values and see if I can
tighten it up a little.
A few great things, the tone stack with a mid control sounds great. It is 100% usable. Both the tone and mids. It really opens up the versatility of the circuit. The other thing is that it has a lot of volume on tap. Way more than that other big muffs I have had in the past.
iainpunk
if you want a 'tighter' sound, you can decrease the capacitor value coming off of the first transistor, going to the 'sustain' control, this leaves out some bass and tightens the character up a lot.
cheers
cheers
OiMcCoy
So after tinkering for a bit and coming up with something that really works well for my bass, I decided to try out my new Tele with it and was shocked to find how little gain it has compared to a normal Muff. So my first instinct was to think I failed at my goal. But then I played around with it some more, then bypassed it and heard how shitty my guitar tone was. But once I switched it back on I started using it as a preamp type pedal. And I got to say, it sounds pretty remarkable in this roll. I can still get some fuzz out of it at max setting, but the main draw for me is the mid control gives the circuit such a lush tone for my not so lush ceramic pickups.
Now my question is how do I keep this goodness that I discovered while increasing the gain a little? Should I make the first boost circuit hotter, or the clipping circuits? Or do I just throw another boost in front?
iainpunk
Quote from: OiMcCoy on March 20, 2021, 09:47:16 AM
i'd say build another boost (or a few) to boost in to the modded muff, that gives a bunch of flavours of drive
cheers
cheers
antonis
Big Muff is a pedal of more than 40dB gain so I think you have to play with HPFs corner frequency rather than boosting it more..
P.S.
Unless you have some ultra clean transparent boost builds in mind.. :icon_wink:
OiMcCoy
Quote from: antonis on March 20, 2021, 03:36:31 PM
P.S.
Can you break this one down for me layman mind?
Are you talking about the bias?
If it helps I am using 5088's for all four stages.
antonis
More boost means more distortion (in an already high gain circuit..)
There are plenty of high-pass filters to play with..
OiMcCoy
antonis
#31
Big Muff already has 5 HPFs (one for each of 4 gain stages and another one on Tone control) so you don't have to put an additional one..:icon_wink:
P.S.
We might are talking for different cases so if you wish to boost Big Muff simply put an electro cap (10μF to 47μF - the bigger the cap value the more the bass amplified) in parallel with last recovery stage transistor Emitter resistor..
