Is slower sampling doing the same thng as bit reduction?
Started by Mark Hammer, March 27, 2021, 03:00:54 PM
iainpunk
#20
QuoteI wonder how much difference would be audible comparing a pair of bit crusher and aliaser with perfectly set up “staircases” (theoretically, obviously difficult) and fed  white or pink noise vs pure waveforms, like sine.
i have the necessary tools on my computer, i can do some sine waves in to either sample and/or level reduction. ill keep the sample speed the same, while sweeping the input volume, and then sweep the input frequency while keeping the volume the same, to showcase the difference.
ill post a link to sound files later.
https://vocaroo.com/116CoTAmHXZx
first is a clean plonk, then sample rate and then level depth reduced, then its the same effects with a sweep
cheers
cheers
