Ibanez FL-301 - IC106 blown
Started by silenttransmission, April 17, 2021, 09:40:35 PM
silenttransmission
Hi, new to this forum and could use some help.
I have a Fl301, but the IC106(voltage regulator) is blown. Where can I find a replacement.
Thanks!!
Welcome!
Schematic:
https://www.tdpri.com/attachments/ibanez_fl301_sch-pdf_1-png.763772/
Regulator is identified as a MC78L12CP
The "MC" is just the maker. The "L" identifies the small TO92 package, not the power-tab package. (The pinouts are different.) "CP" is the old code for Commercial Plastic (as opposed to military or metal).
It looks like nobody uses the "CP" suffix today; there are more complex codes now.
You want a 78L12 in a TO-92 3-leg package.
You want to say where you are (UK? Can? Peru? HK?) so someone can suggest a good vendor accessible to you.
https://www.futurlec.com/Linear/78L12pr.shtml
https://www.mouser.com/ProductDetail/ON-Semiconductor/MC78L12ACPREG?qs=%252B9%2Fcbd0IE0TRpg8aUg7a5Q%3D%3D
http://smallbear-electronics.mybigcommerce.com/ic-78l12/
silenttransmission
Thank you very much!!
I have just started to learn.
I'm from Uruguay, South America.
