Fuzz Circuit Stage Questions
Started by bushidov, May 15, 2021, 10:16:05 AM
bushidov
Hi All. I am working on trying to understand a transistor amplifier stage I've been playing with and have a couple questions.
Firstly, the schematic:
So, I see that it is a transistor amplifier, but is using a combination of an NPN and a PNP. It isn't a Mu Amp or a Sziklai pair, but I am not sure "what it is". Interestingly enough, the waveform is pretty cool.
Green being a 100mV 1kHz input signal, blue being the output.
Aside from the bias being a bit off, it looks like the signal isn't really amplified at all, as a buffer, but the -1.0V dips clearly shows a sign of amplification.
So how does this work?
Does this topology have a name?
Should I have drawn the schematic differently, and that would have helped me answer my own two first questions?
What say all you folks?
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away."
- Antoine de Saint-Exupéry
where/what is that originating from, if I may ask? it looks like "a doubler", but it also looks to be missing bias, and a resistor to ground, and it looks miswired.
" I will say no more "
iainpunk
its a voltage follower and a Bazz Fuss in one, as the diode function of the PNP basically does what the Bazz Fuss's diode does as well, but its connection to ground makes it a voltage follower when the NPN is not conducting at all.
i used this topology in a fuzz pedal before, with a 100k instead of the 10k, and it was driven by a Jfet gain stage.
later found out that Devi Ever also used in in one of his fuzzes.
cheers
cheers
Fancy Lime
Quote from: iainpunk on May 15, 2021, 11:35:49 AM
cheers
...her fuzzes.
bushidov
Thanks all, yeah, that was a real "duh" moment for me there. I've used transistors as diodes for other things too and just didn't see it.
