Green Ringer / One Knob Fuzz
Started by dstraiton85, May 21, 2021, 06:02:37 AM
dstraiton85
Hi All
I'm hoping someone can help a kinda noob out.
Ive built a green ringer and a one knob fuzz. The idea is to house them in the one pedal, separate footswitches and a switch to change the order.
All was going well, The green ringer works perfectly  on its own, the fuzz works fine on its own. When i play the green ringer into the fuzz, it seems to work quite well.
The issue i have is that when i play the fuzz into green ringer i get a squeal sound when im not plying the guitar.
As they all work well separately and in one order, I'm racking my brains. Is this an known issue? should i be doing something to the signal coming out the fuzz?
Thanks in advance.
Donald
antonis
Hi & Welcome.. :icon_wink:
Green Ringer has an output buffer, so it doesn't mind for next effect input impedance a lot..
One knob Fuzz output impedance is quite high (Collector resistor in series with Volume pot lug 3 - wiper)..
What is the value of one knob fuzz Volume pot..??
P.S.
Could you post a schematic of effects order switch wiring..??
dstraiton85
#2
Thanks for this. I had a feeling there was something funny going on.
The fuzz pot is a 500k log pot.
The One knob fuzz i have is:
Only difference is im using a 100r resister at the top, and two BC108C (high gain i know) for Q1 and Q2.
The green ringer is:
Using a 20k pot. No other changes.
Thanks again
antonis
#3
Very well but you didn't post the effect order switch selector.. :icon_wink:
In case of switch wiring is OK, you'll have to try placing another 220pF (or so) cap between Collector & Base of Q2 (like the one in Q1)
in Fuzz layout..
P.S.
From correct design point of view, a Fuzz output buffer should be the ultimate solution, but it shouldn't be a Fuzz anymore..  :icon_biggrin:
dstraiton85
Of course, sorry. Im using an order switcher from fuzz dog..
dstraiton85
I tried adding the 200p cap and it cut the whole sound.
Looks like i will have to tinker around with an output buffer of some sort.
Thanks again for your advice.
antonis
Quote from: dstraiton85 on May 21, 2021, 07:21:36 AM
Can't imagine how this happen.. :icon_eek:
