I have 3 veroboard circuits ready and want to know if theres any issues or not
Started by snow123, May 25, 2021, 02:42:55 PM
caspercody
When I do a vero board, I always use a meter to make sure there are no shorts after I drill out the holes. This I do before I populate the board.
Once I am done with populating the board, I again use a meter to test for shorts again around the drilled holes, and from each row to the nearest row. I have in the past found issues and able to correct easily before I connect wiring.
