Dr Boogie gain pots for less gain?
Started by ghostsauce, May 09, 2024, 11:11:27 AM
ghostsauce
Hey guys been a long time hope you all are doing well
I've built another dr boogie cause i love these things, and this time i went with additional gain/volume pots for a pseudo second channel.. and now i am looking at fine tuning the gain pots because the 1mA is just an insane amount of gain and i want about 1/4 to 1/3 of it to make the knob more useable. I tried a 500k and it still has far too much, so i'm about to put in an order for a few different values and was wondering if anybody here has used 100k's or less in these with any luck?
ghostsauce
Also look at this beautiful thing. Left side is the boogie, right side is a rog tonemender. it's one hell of a 3 channel preamp
FiveseveN
It's a voltage divider, the value of the pot has little to do with how much signal it attenuates unless you go to extremes and approach the source impedance.
Stick a resistor between input and pin 3 of the pot. https://www.build-electronic-circuits.com/voltage-divider/
ghostsauce
I'll give it a shot but I've come across people mentioning this, won't it accomplish the same thing as using a different pot value except also destroy the log taper?
FiveseveN
Not at all. Did you read the article?
Having refreshed my memory of the schematic, there's already such a pre-attenuation resistor, though bypassed by C6. It means the source Z is significant, for low frequencies at least.
antonis
#5
Quote from: ghostsauce on May 09, 2024, 11:11:27 AMthe 1mA is just an insane amount of gain
Are we talking about current gain..??
ghostsauce
Scratch that, it was just poorly biased. now the gain on tap is pretty much all useable so there's no need to adjust the pots, but i appreciate the input. thanks folks
ghostsauce
Quote from: antonis on May 09, 2024, 02:50:57 PM
Are we talking abour current gain..??
i meant the 1m audio taper pot not amps, haha
FiveseveN
ghostsauce
i think the MA stands for mega awesome iirc
ghostsauce
