pedal ideas for 3d printer
Started by JohnForeman, December 24, 2013, 08:42:17 PM
iainpunk
nice knob print, this could benefit a lot from some acetone vapor smoothing, to take out the grainy-ness and match it better with he smooth finish of the originals.
but a cool print nonetheless!!
cheers, Iain
cheers
matmosphere
I've been messing around with printing faceplates for pedals.
Had some promising results so far.
I really dig those little control labels
Processaurus
#42
Resin print of the same mutron knob, it even did the splined shaft part.
You could print up Nigel Tufnel knobs that go to eleven.
For occasions where you need a reverse log taper pot and they are difficult to get in the value and form factor you want, print up a set of two spur gears to reverse the rotation of the knob.  You can hide this under the surface of the effect or put it prominently on the front for a steampunk pedal effect.
stallik
Such a gear could be used to turn volume down when the gain goes up
Phend
#45
As my business card says, " Your imagination is not the limit ! "
PS, what do we do ? Make DIY Effects, ya ! Lots of em !
  • SUPPORTER+
Do you know what you're doing?
Fancy Lime
Quote from: Phend on September 14, 2022, 05:39:58 PM
Gene Roddenberry thought TV would last until 2040? Bless his heart...
You could make the most difficult part of a wah pedal - the rack and pinion and the slider that keeps them meshed with each other.  Since you can control the design, you could make it an internal or external spur gear so you have a pedal and gear as a single unit without the pivot you need for a rack.
