Optocoupler substitution in voodolabs switching circuit...
Started by mdcmdcmdc, March 30, 2022, 01:51:29 PM
mdcmdcmdc
Hi folks,
PJP started an optical switching thread last week that led me to find the schematic for voodoo labs' switching scheme:
I've also seen a version that replaces the photo-FET with transistor-output:
Here are the respective datasheets for the two optocouplers that voodoolabs uses:
https://www.mouser.com/datasheet/2/308/FairchildSemiconductor_161480151644-1192009.pdf
https://www.mouser.ca/datasheet/2/408/TLP181_datasheet_en_20190617-708235.pdf
Seems like either a FET or transistor output device will do the job, so my question is - if I'm looking for substitutes, what are the important specs?
I was planning on ordering some stuff from Tayda sooner than later, and they have both the 4N25 and 4N26 available, which are transistor-output with an additional base connection in the 6-pin package. Would either of these do the job?
1) Price.
2) Size
This is not a tough job.
mdcmdcmdc
I'll give it a whirl with the 4N25/26 and see what happens then. Merci!
mdcmdcmdc
The 4N26 works a-ok.
Ironically I'm using 2/3 of a 3PDT to test it, but it defeated a pop that I couldn't otherwise get rid of in this particular pedal so I'll take the win where I can.
