Sola MKIII and guitar's volume knob
Started by alange5, October 07, 2016, 11:51:30 AM
angelodp1
I know this is an old thread... for the 3 knob Tonebender, would trimmers for bias be in order on all three collectors? I have a build I like and want to finesse the bias. Would 10k trimmers at the collectors do the trick.
Harry Muff
Quote from: anotherjim on October 07, 2016, 02:27:20 PM
None of those transistors are biased - going by the base-emitter voltage difference. PNP, the emitter should be more positive than the base by around 0.2V?
Do you have the power supply polarity right? This is positive ground. Easy & frequent mistake - rookie or not.
Or maybe that 220k bias resistor is too high value or missing - or the 47k bias is really 4.7k (might explain the darkness). Anyway, look thereabouts.
they should just redraw these layuts with trimpots !! im not that talented or I would alter the drawing for variable resistors
Harry Muff
Quote from: angelodp1 on March 02, 2022, 10:36:35 PM
didnt see this but that is what I suggested .. all the drawings should be redone for variable pots
mdcmdcmdc
I haven't found TB MKIIIs to be particularly fussy when it comes to bias or voltages. It's a great sounding circuit that's very forgiving.
