Neo Vibe Speed UP
Started by spoontex, May 14, 2022, 10:53:37 AM
spoontex
Hello,
How can I increase the speed of my Neo Vibe? It's slow compared to deja vibe, easy vibe, gypsy vibe and others.
antonis
Study R.G. analysis : http://www.geofex.com/Article_Folders/univibe/vibeupdate.pdf
In case you don't get your goal, come back and ask.. :icon_wink:
spoontex
Quote from: antonis on May 14, 2022, 11:15:43 AM
down the R42 and R43 resistors?
antonis
Althought it should be plane enough to answer with a "yes" or "no", it should be more creative to undestand what you're doing.. :icon_wink:
So, plz read 5th paragraph of LFO chapter here: http://www.geofex.com/article_folders/univibe/univtech.htm
(it's only one and a half row but if you get the way particular time constansts work, your issue will be considered settled..)
spoontex
Quote from: antonis on May 14, 2022, 11:38:32 AM
Yes, R42 and R43. Thanks for the info!
Almost always, the resistors are selected for the DC conditions and should not be changed much. The capacitors have no DC effect and can be changed a lot.
Also in this case, changing R means changing pot which is already paid-for and mounted. A few caps is usually cheaper and easier.
Three 0.47uFd will wobble twice as fast.
