Strat Megaswitch S Question
Started by spoontex, September 11, 2022, 04:55:12 AM
spoontex
Hi,
I've a standar stratocaster with Seymour Duncan pickups. STK-S7 on neck and middle and a Trembucker 59' on bridge. Actually I have this configuration.
Position 1: Bridge
Position 2: Middle + Split Bridge ( cancel south coil )
Position 3: Middle
Position 4: Middle + Neck
Position 5: Neck
This is the HSS3 wiring from Schaller.
Now I want to try the HSS2 wiring, but I noticed that the only difference respectively to HSS3 is that in position 2 the red and white cables joint to neck pickup.
Is that correct? I always thought that for splitting the north coil of a humbucker I need another wiring.
Anybody can help me?
Thanks.
https://schaller.info/en/megaswitch-s
