Gretsch Expandafuzz
Started by tommy.genes, December 21, 2007, 10:21:56 AM
tcobretti
Austin73
Cheers for the schem Mike.
What are the IC's used?
RG you up for doing a layout still? lol
Thanks everyone for jumping on this
Aus
Bazz Fuss, Red LLama, Harmonic Jerkulator, LoFo MoFo, NPN Boost, Bronx Cheer, AB Box, Dual Loop, Crash Sync
tommy.genes
#22
Thanks for posting the schemo, Mike.
Notable points based on first-glance analysis:
  • The Expandatone circuit is completely after the Controfuzz.
  • The Expandatone is still "in" the circuit even when the Controfuzz is bypassed.
  • Mark H. was right about it being three parallel EQ circuits.
  • The TREBLE, MID-RANGE and BASS switches don't really "remove" the EQ circuits, but instead effectively turn the knob to the lowest setting.
I'll continue to look at the circuit once I'm back in the office next week (when else do I have that much "free" time?), and I look forward to any further insights from Mark, R.G. and others.
[edit for typos]
-- T. G. --
"A man works hard all week to keep his pants off all weekend." - Captain Eugene Harold "Armor Abs" Krabs
antojado
General Guitar Gadgets has a schem. and layout for the controfuzz so you could start with that and modify it or build another board to add to it.
http://www.generalguitargadgets.com/pdf/ggg_controfuzz.pdf
The GGG file says the original ic was an LM748, but this schem. says UA748. http://www.cirlab.uniroma2.it/Courses/TC_TechSup/doc/DataSheet/slos095.pdf
Here's another schem. of the controfuzz: http://www.freeinfosociety.com/electronics/schematics/audio/gretschcontrofuzz7798.pdf
Rob Dobbs
Im not eager to tear apart my favorite pedal but if there is an experianced builder in the south bay los angeles area drop me a pm.
John Lyons
#25
So where to the "TP1, 2,3 and 4 points connect?
Oh, maybe Test Points?
Basic Audio Pedals
www.basicaudio.net/
andy-h-h
Quote from: John Lyons on January 27, 2022, 07:51:29 PM
Bit late to the party as they say....    I was having a look at this today on spice, and spent some time looking at the photos of circuit boards posted.   The 10k resistors from the opamp outputs to TP points don't appear to connect to anything.
I'd say you're right.  Just test points.
