A delay pedal anyone can build for cheap!
Started by gcwills, June 21, 2018, 10:14:00 PM
Quote from: Marcos - Munky on June 22, 2018, 12:59:41 AM...about $5.50 with shipping to Brazil based on the price in reais (brazilian coin)....
That link is quoting me US $1.58 marked down from US $1.80.
Although-- Shipping: US $1.80 to United States via Cainiao Super Economy Global Estimated Delivery: 30-50 days
Domin
I made pedal with it today
Its not boxed yet, but it has dual buffer pcb for input buffer and output blend, i desoldered R27 and put 50K pot, maybe ill add some small resistor in series with it
Puguglybonehead
I'm thinking of using one of these in a busking amp I'm trying to build. Using a modified Supreaux as the preamp and using a small class D board as the power amp, running it all at 12v. (8 x C-cells) Has anyone tried running these boards at 12v?
The listing on AliExpress reckons that the board will run off 5-15V. There's a 78u05 regulator on the board, so it should be ok. At 12V the regulator will drop quite a lot of voltage, so you might find it gets hot.
If you were worried you could replace it with a 7805 in a TO220 package. The metal tab on those acts as a decent heatsink and they're well over-specced for a job like that so here'd be no danger of cooking it. But if it ain't broke, don't fix it - try it and see first.
