Voltage reference with bipolar power supplies
Started by Labaris, October 18, 2022, 11:15:58 PM
Labaris
Hi!
I'm working on a design that will use a bipolar power supply. I'm going to reuse a preamp design I originally made to use as a pedal.
My question is, the original VCC, GND and VREF (VCC/2) correspond to which nets in the bipolar-PS version? My guess is:
VCC is +VCC, GND is GND (only now it is half of the supply voltage), but I have no clue about VREF (and I might be wrong about the other two).
Power supply output:
Example of the pedal version of a circuit:
A long way is the sum of small steps.
The easiest way I can phrase it is:
- opamp +rail:         was +V   now +V
- opamp -rail:          was gnd  now -V
- everything else:    was Vref   now gnd
                             was gnd    now gnd
This is an over simplification but tends to be "the algorithm" for audio circuits.
antonis
Labaris
Quote from: Rob Strand on October 18, 2022, 11:23:48 PM
                             was gnd    now gnd
