Tc Electronics Etemaster - adding a volume knob at the input?
Started by nothing_nothing, December 23, 2022, 03:59:25 AM
nothing_nothing
Hello, my TC Electronics Eyemaster pedal gets kinda muddy and loose with high output pickups, but if I lower the volume knob on the guitar it gets tighter and crunchier in a very good way :D The problem is that some of my guitars don't have a volume knob...
I would like to add a second volume knob, so I could adjust signal going into the pedal, but is it even possible? Because whole pedal has a switch and input/output soldered into the board.
I am total noob, so talk to me like I am five :) I can solder some cables and a pot, but not much more.
There is already topic about modding this pedal, but it's about adding Hi/Low knobs: https://www.freestompboxes.org/viewtopic.php?t=30392
Dormammu
Why not add volume to guitars — is a very useful feature.
Also, it is not necessary to turn the gain 100%, all the time.
nothing_nothing
Quote from: Dormammu on December 23, 2022, 04:26:14 AM
I have a guitar with a stone top (made of granite), it's nearly impossible to drill a hole in it :( Second has no knobs and I want it to stay clean.
FSFX
Why not just put a volume control pot in a small ABS enclosure and wire it with a jack plug and short lead to the guitar and with a jack socket to plug your normal guitar lead into. A bit like some of the early small boosters that plugged into the guitar output socket.
Or something like this:
https://www.amazon.co.uk/AudioStorm-Control-Pedal-Guitar-Bass/dp/B07RL8MMWK/ref=asc_df_B07RL8MMWK/
antonis
A DIY Expresion pedal should be fine.. :icon_wink:
(search for a Wah shell/enclosure..)
FSFX
Quote from: antonis on December 23, 2022, 05:04:48 AM
You can actually get volume (or swell) pedals ready made.
antonis
Dormammu
Quote from: antonis on December 23, 2022, 06:01:18 AM
Quote from: FSFX on December 23, 2022, 05:53:10 AM
But we are a DIY forum, no..??  :icon_biggrin:
We can call it — diy substitute volume control.   :D
FSFX
Well it just depends on your definition of DIY and that applies to many things in life, not just stompboxes.
