Working on tube amps with a ungrounded home AC....
Started by momo, May 08, 2023, 08:03:55 AM
momo
So here I go into tube la la land with my first tube project, converting a tube PA amp for guitar.
Now I live in this old apartment that does not have upgraded grounded AC.
They installed a GFI tripping thing at the start of the circuit (20amps) if it sees voltages on ground, so thats the protection I have.
I will be using a isolation transformer/variac so I'm all good, I was just wondering if I missed any details on this AC setup.
"Alas to those who die with their song still in them."
antonis
Could you plz show trhe way you intend to utilize it..??
momo
I have not built yet,
Basically it would be a suitable transfo fed by the mains and then that into a 2.5 amp variac.
Without the ground connected at the output.
I realize this is a touchy subject as for the danger of playing with these things.
I just want a heads up on details I have not seen.
I am watching many videos on how to build one, seems strait forward ..
antonis
#3
I presume you're talking about something like below:
P.S.
Plz Mario, unless you really know what you're doing, don't do it..!! :icon_wink:
momo
Something like that yes.
Thanks for the warning.
I'm reading much, I mean everyone has a first time, thanks.
I just finished building a capacitor discharge wand, on to the current limiter.
MetalGuy
Some areas in Europe to this day don't have dedicated ground line so everything is "grounded' to the neutral (0-line) without any problems. That applies for tube amps as well.
antonis
Quote from: MetalGuy on May 08, 2023, 04:07:04 PM
I may assure you there are A LOT of problems in such a wiring configuration.. :icon_wink:
