charge pump voltage divider issues?
Started by karsten_h, January 22, 2024, 03:34:20 AM
antonis
Quote from: karsten_h on January 22, 2024, 05:35:41 PM... think so?
https://www.musikding.de/LM317T
Could you compare its cost with its negative version (LM337T) in the bottom of the page..??
Anyway, in case you need a variable dual PS, you better build one, like below.. :icon_wink:
(although, it should be more effective to use a center tap transformer..)
karsten_h
finally i kept it simple and build something like the one from electrosmash...
can you tell me why in this build the capacitors from pin5 go to +9v? every other schematic says they go to ground...
another question:
ist there an error? fried two leds using this build so i left it blank... the resistor is on the wrong side of the led? is it?
... just standing on the shoulders of the diy stompbox scene out there.
