Bypass pop and current limiting resistors
Started by DIY Bass, July 11, 2023, 05:07:03 AM
Quote from: GGBB on July 14, 2023, 08:41:23 AM... 9V supply and 1.8V LED - the current surge when the LED is turned on will be >20mA through the 330ohm resistor. ...
It is 22mA for part of 3 milliSeconds.
I don't think it is an LED killer.
antonis
Quote from: GGBB on July 14, 2023, 01:19:30 PM
Not sure how long a 10ยต cap will hold charge in that configuration. Only "perfect" caps would hold the charge permanently. Real caps especially aluminum electros will eventually discharge. Seconds? Minutes? Hours? ...
The more the cap "imperfection" the better for LED health.. :icon_wink:
A fully discharged cap is ideal for RC time constant delay estimation..
GGBB
Quote from: antonis on July 14, 2023, 04:43:31 PM
But how would it help with switch pop?
GGBB
Quote from: PRR on July 14, 2023, 03:19:46 PM
It will depend on the LED and the supply voltage, but it's the bright flash that's the main problem. Why risk it? Is there some advantage to using 330 vs say 1k?
antonis
Quote from: GGBB on July 14, 2023, 10:50:57 PM
By progressively decreasing shunt LED current...
Has anyone tried the LED from a laser pointer as their indicator?  It could be made less dangerous with a diffuser but you could probably use one at low current where the bypass pop would be less than normal.  You can get them in all the colours that LED's are made in.
Phend
#27
These Lamps are very bright, see size compared to a red led.
  • SUPPORTER+
This is the age of Video Game Induced illiteracy
