Resistor across pot values
Started by SprinkleSpraycan, August 13, 2023, 12:39:17 PM
SprinkleSpraycan
Okay, I need a dual gang b10k pot. But I only have b50k dual gangs. So I soldered a 15k resistor across the outside lugs. But I hit 10k around 7oclock, spike up to 16k around 2oclock and then down to 10k fully clockwise.
Why? How to I get rid of this hump?
I've used this method before without this problem albeit on larger values. Confused.
idy
The R goes from the wiper to one of the outside lugs.
Phend
#2
https://www.diystompboxes.com/smfforum/index.php?topic=66471.msg528211#msg528211
Look at reply #19 on this topic
Plus the rest of the reply's for the nitty gritty of doing this.
And downfalls of such.
  • SUPPORTER+
Do you know what you're doing?
If it's for some sort of frequency control you might be better off using frequency caps 5 times smaller.
Always pays to check if the change affects any surrounding circuit.
SprinkleSpraycan
Quote from: Phend on August 13, 2023, 02:28:21 PM
Yes! Thank you. Lots of good information on that thread.
