MN3101 clock replacement now available at Cabintech.
Started by digi2t, September 14, 2023, 06:41:30 AM
digi2t
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
Govmnt_Lacky
Great news! Now, if they only had a 3204 replacement so I could build my Flange-a-rama then I would be set  :(
It's an SMD 4047 on a little PCB, with a couple of resistors to give the Vgg supply, so unless you're replacing an existing MN3101, just forget it and design your layout for the 4047. Their testers basically all say that there's no difference.
There probably will be some differences in terms of maximum number of stages that can be driven, and maximum speed they can be driven at, but in those situations (delays for the first, flangers for the second) these chips are usually buffered anyway, so it's likely to be a moot point.
StephenGiles
Quote from: Govmnt_Lacky on September 14, 2023, 09:29:12 AM
...............to say nothing of the SAD1024 replacement!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Quote from: StephenGiles on September 16, 2023, 06:30:18 AM
Yeah, some new-production BBD with *less* clock capacitance than Panasonic managed in the 70s would be nice! Bonus points if it improves on the S/N too.
CheapPedalCollector
Replacements for all the RETICON chips would be nice. With some improvements go prevent burnout, and lower noise.
StephenGiles
