Question about ceramic caps readings
Started by eh la bas ma, November 02, 2023, 06:18:48 AM
You should light the wood dowel posts to give you a tiki torch effect.  Should look awesome on stage.  Would also give interesting effects as the posts burned away and the circuitry sat on the baseplate in a heap.  Put it up on the projection screen at your concert and see if the audience has a clue what is going on.
Phend
Hum, can't tell from photo, posts are solid copper. Maybe apply high voltage and turn it into "Ole sparky"?
  • SUPPORTER+
Do you know what you're doing?
Phend
#43
Hint:
Start with your copper traces far apart.
0.01 inch or even 0.04 inch is close.
But needed for a small box.
Else you would need a Big box.
  • SUPPORTER+
antonis
#44
I give you a big dislike, Phend.. :icon_mrgreen:
Those 16 x 16 mm knobs aren't fancy enough..!!! :icon_lol:
(not to mention than toggle switch without glitzy rubber boot cover..)
Phend
Another questionable photo, what looks like rubber is it's cousin plastic.
(I believe that is black part you refer to)
I must apologize for any inconvenience, and those are my favorite knobs, (they come off)
  • SUPPORTER+
antonis
Quote from: Phend on November 05, 2023, 01:14:33 PMI believe that is black part you refer to
Nahhhh..
I'm talking about Toggle switch lever cover.. :icon_wink:
Phend
Wow, do they come in orange ?
Since I have used a lot of these toggles, I shall look for those rubbers.
Extra large ??
  • SUPPORTER+
antonis
Quote from: Phend on November 05, 2023, 02:22:11 PMWow, do they come in orange ?
Extra large ??
Older people might remember,
"Sure, we got lubbers!"
At 30:13,
