CAN I USE MN3207 INSTEAD OF MN3007 TO BUILD CE-2 CHORUS
Started by litstalov, June 07, 2013, 11:54:41 AM
Govmnt_Lacky
Quote from: Baran Ismen on November 17, 2023, 03:56:26 AMBeating a dead horse here for the very same inquiry. Theres a daugtherboard for 3007 to 3207 but im unsure about the voltages. Also their datasheets state that they both have same pinout, what about that?
MN3007 works on (up to) -15V DC
MN3207 works on (up to) -5V DC
Translation: If you put a 3207 into a circuit designed for 3007, it will kill it.
Baran Ismen
Quote from: Govmnt_Lacky on November 17, 2023, 07:40:13 AM
Most likely. But on Aion's of PedalPCB's schematics, I didn't see any voltage divider for 9V pins. Its max voltage rating is ~11 and works between 4 to 10, here says.
