1S34 diode
Started by jlo, December 13, 2023, 06:54:38 AM
jlo
I'm trying to find some info on the 1S34 diode.  I believe its germanium.  I have a couple but I don't have a means to test the forward voltage.  Anyone know?
Thx!
antonis
m4268588
I don't know if I own Toshiba's products. And it's just one sample.
antonis
Quote from: Rob Strand on December 14, 2023, 12:01:51 AM
::) Interesting enough.. :icon_wink:
Considering all diodes obey to Schokley equation, what counts in current ten-fold proportionality is IS (reverse bias saturation current) order of magnitude..
(it should be good to know for what forward bias current Ge & Si voltage drops are equal..)
Quote from: antonis on December 14, 2023, 06:52:48 AMConsidering all diodes obey to Schokley equation, what counts in current ten-fold proportionality is IS (reverse bias saturation current) order of magnitude.
The Is term in the Schottky diode equation isn't constant.
This classic paper fills in a lot of the missing details. Mainly equations (1) to (5).
https://xdevs.com/doc/_Metrology/tsividis1980.pdf
Spice knows about the T^3 term in equation (3).
If you try to derive the VBE or VD temperature coefficient for a transistor or diode you need all those details to get the well known -2mV/deg C.
