Boss FS-6 clone
Started by I am the Walrus, December 18, 2023, 04:31:37 PM
I am the Walrus
Does anyone know of a Boss FS-6 clone that will work
with the hold function on the SY-1 Boss synth pedal? Thanks for any help on this.
From reading the manual, it looks like any momentary footswitch would work. Probably normally open.
If you've got the pedal, stick a jack lead in the EXP/CTL socket, and then short tip and ring together on the other end of the jack lead with a coin or screwdriver or something. If that works, then it's a normally open momentary switch.
