LTspice problems
Started by Yoshi, December 25, 2023, 04:46:50 PM
Yoshi
Hi... Im tryng to do test´s int LTspice. Im coping a tubescreemer... but when i Run the program, the signal dosen´t work....
Do anyone has an idea? thanks a lot,
happy Christmas
Quote from: Yoshi on December 25, 2023, 04:46:50 PMHi... Im tryng to do test´s int LTspice. Im coping a tubescreemer... but when i Run the program, the signal dosen´t work....
Just Human error, C6 connected to wrong point.
At some point try a larger R7.
GibsonGM
Quote from: Rob Strand on December 25, 2023, 05:56:40 PMAt some point try a larger R7.
Good eye, Rob.
And then try an output cap/pulldown resistor to get rid of that pesky DC offset.
mac
Use a guitar mic model as your input signal. Maybe not needed here because of the input buffer but sometimes the guitar circuitry interacts with the effect input impedance, e.g., Rangemaster.
mac
Yoshi
Thanks!!!! you are the best
