Replace voltage divider chorus depth pot with a toggle switch?
Started by guitylerham, January 09, 2024, 03:47:46 PM
guitylerham
Howdy,
I built a Madbean Pork Barrel Chorus and am adapting it to my custom enclosure and need some advice on how I can omit the Depth pot in the circuit and replace with perhaps a 2 or 3-position toggle switch. There is only space for two pots and a small toggle and currently I'm going with Rate and Blend pots.
Here's the section of the schematic:
I've never done this to a pot wired like divider (compared to just a variable resistor). My thinking is, maybe I can leave a 100k resistor in the circuit but somehow switch in/out other resistors to simulate 2 or 3 "tap" points along that 100k. I just can't quite wrap my head around this at the moment. Anyone else do something like this before?
guitylerham
Ah, I just had to do a bit more research but this seems pretty doable. I'll just need to decide what my preset tap points need to be (i.e. max depth, med depth, etc).
I posted too soon! this can be deleted if it's of no use to anyone. Thanks!
Quote from: guitylerham on January 09, 2024, 03:56:38 PMAh, I just had to do a bit more research but this seems pretty doable. I'll just need to decide what my preset tap points need to be (i.e. max depth, med depth, etc).
Nice work. Simple but effective.
GGBB
Never mind - was thinking of something else.
