multi looper switcher diagrams
Started by andomando, May 12, 2024, 09:42:04 AM
andomando
I have been trying to wire up a multi switcher loop pedal 5 effects only. But every diagram i have wired from wont work..and i checked all the wiring each time i tried a new one with total failure and the wiring matched each diagram ..Now i have done many soldering jobs through the years and never had this problem before..Does anyone have a diagram i can try...any help would be appreciated.
show us your circuit and your failed build/s. you never know what we mind find.
" I will say no more "
+1 what Duck said. Show us some of the diagrams you've tried and tell us what you did, and we'll have a look and see what we can find.
Quite often, just the discipline of drawing the switcher diagram will show you where the problem is.  It is often something obvious that you don't see until you draw it on paper.
