A different NPN germanium transistor for use
Started by Mark Hammer, May 30, 2024, 06:13:29 PM
Boxing up a Fuzz Face type circuit that I made using 2SC281 transistors.  One tends not to see these talked about, but I have to say, they sound respectable in this application.  As the "prime candidates" begin to disappear, it's nice to have other choices to turn to.
Some guy "Mark" was doing these a dozen years ago.
https://www.diystompboxes.com/smfforum/index.php?topic=99898.0
Radiomuseum lists it as "Silizium Mesa NPN". Mesa construction may be different enough from planar to matter.
https://www.radiomuseum.org/tubes/tube_2sc281.html
Is there an emoji for facepalm-drawing-blood?
I have a small storage unit with a bunch of populated boards, perf and PCB, that aren't wired up.  I pulled this one out and decided to box it up.  Ironically, the name I legended on the enclosure was "Are You Positive", alluding to the supply voltage and transistor polarity.
I just pulled one from the bin and the forward voltage between base and the other leads. And yes, it reads over 700mv so it's a silicon unit.  Crazy thing is that I obtained these Hitachi transistors as part of a blister-pak of actual germaniums I bought from a local surplus place that was going out of business.  Each blister-pak was a variety of 5 or 6 Japanese transistors (including 2SB33, 172, 173, 175, and others) that all have the exact same appearance.  These were commercial blister-paks so it wasn't anything devious on the part of the store.  The same rack had blister-paks of capacitors and 1W resistors, etc., each one having a visible uniformity of contents (e.g., five identical "tropical fish" caps).  I guess whoever packaged them originally, and sold them to the store had simply shoved a bunch of Hitachi trannies onto these cards.
Weird.  But your memory impressed me, Paul.  Can I at least claim that, since it was 12 years ago, (I can be forgiven for forgetting?  Mind you, this abundantly illustrates just how long an "almost-finished" circuit can sit around my bench, waiting for the last lap.
antonis
Quote from: Mark Hammer on May 31, 2024, 07:13:55 AMthis abundantly illustrates just how long an "almost-finished" circuit can sit around my bench, waiting for the last lap.
Still far from eternity.. :icon_wink:
Quote from: Mark Hammer on May 31, 2024, 07:13:55 AMyour memory impressed me
No memory. That thread was one of the first hits for the part number.
One application I saw was a full radio (actually CB) mostly PNP Ge like (not same-as) the numbers you cite, but the 2nd audio was this NPN Si. So maybe someone was stripping radios or found a lost supply bin.
Ah, this is mostly NPN, but does have the odd genders in the audio.
