Pour on epoxy finish
Started by rousejeremy, June 26, 2024, 05:18:03 PM
rousejeremy
Can this stuff be brushed on in thinner layers or do you have to dump the whole thing to get the self levelled shiny look to it? If so, what kind of brush? I ask because the few times I've used epoxy the top of the box looked great and the sides looked like crap being all big drips.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
mark2
This is just an anecdote in case anyone nobody has a more comprehensive experience...
My son brushed mod podge on his pinewood derby car and even with thin coats, it left a distinctly brushed texture. This was fine for the project at hand, but I was paying attention and curious how it would look with pedals. YMMV with other products or techniques of course.
Focalized
I used it a couple times and the sides were also messy. I taped over the sides once so it only covered the top then just used clear spray for the sides.
I now just go with light clear coat and bake. Shake n bake. Hardens up pretty quick. So as long as there's no moisture or oils left on your base coat that might bubble up from the heat.
GibsonGM
I've used pour-on 'bar top epoxy' a few times for customers.  It's great around sinks for things such as DIY bathroom vanities made from old dressers etc.  VERY durable. You can use an unlit propane torch to 'pop' bubbles as it cures...you wipe/scrape off the sides where it runs over to prevent that runny garbage look.
I'm doubtful if it has much utility in our world here tho.  Maybe if you had a wooden box?  But you know someone will come along and prove me wrong!   Maybe it could be used to 'pot' a circuit you don't want copied, lol...embed the thing in a solid cube of the stuff!
Katy who? what footie?
