Oomph Overdrive
Started by Aleph Null, January 14, 2025, 06:09:37 PM
Aleph Null
This circuit started out as an Electra Distortion. I kept tweaking and adding features until I ended up somewhere very different. I think it works best pushing dirty amp, but it certainly sounds good on it's own. I think it's pretty versatile, especially given the low parts count.
The knob placement makes it sound cooler...it also required me to use a mix of 16mm and 9mm pots to get everything placed  properly. I attempted a hydro dip finish and failed...so I moved on to a paint splash finish. The perspicacious among you will notice that the PCB is labeled "Electra Supreme"; I had ordered the PCBs before the name came to me.
The soldering around the diodes looks a little sloppy because I tested multiple sets before settling on 1N60s. BAT46, 1N60P, and 1N34A also work well.
An input cap blend acts as a pre-gain Lows control. This feeds what was originally the Electra. The bias is set up so that the Gain can be adjusted without scratching. The real innovation here is the Texture control. This blends continuously between symmetric clipping when fully counterclockwise to highly asymmetric clipping when clockwise. This changes the harmonic content of the overdrive in a way that a normal "mids" eq would not. Next is a make-up gain stage with a presence boost around 2kHz. This is followed by a fairly standard passive Highs tone control and then the Volume.
Here's a demo:
As always, I have extra PCBs if anyone is interested in building one.
soggybag
Sounds great! Nice take on the Electra. It always amazes me that people can still come up with creative ideas in this space!
