Do 9v rechargeable batteries contain charge pump?
Started by soggybag, November 10, 2024, 09:34:05 PM
soggybag
I was helping a friend with an EMG pickup install. We tested it out with a 9V rechargeable battery and there was a high pitched whine. I checked everything and couldn't get rid of it. We switched to a regular 9V and everything was dead quiet. It made me wonder if this rechargeable contains a charge pump?
Quote from: soggybag on November 10, 2024, 09:34:05 PMI was helping a friend with an EMG pickup install. We tested it out with a 9V rechargeable battery and there was a high pitched whine. I checked everything and couldn't get rid of it. We switched to a regular 9V and everything was dead quiet. It made me wonder if this rechargeable contains a charge pump?
I expect so.
You can see a teardown here,
https://budgetlightforum.com/t/disassembly-of-9v-liion-batteries/43352
and here,
https://www.electroschematics.com/9v-usb-li-ion-battery-teardown/
Your whine test is fairly conclusive.
I also suspect they are not all alike.  Some are likely to produce less noise/whine than others.
