LIQUID MERCURY - Tap Tempo 8 Stage Phaser – Mutron Phasor II with TAPLFO
Started by drolo, April 22, 2014, 06:03:54 AM
Ooh, it's an old TAPLFO2 circuit. TAPLFO3 is a drop-in replacement, but you don't need the following parts:
It uses internal pull-ups, so the external 10Ks can go, and it no longer needs an external crystal, so that and the associated 22pFs can go. There's a second set of waveforms on the newer chip available if you want even more options.
Alternatively, replace the TAPLFO with the STOMPLFO and reduce the complexity and knob-overload a bit, while keeping the tap tempo and eight waveforms. It would drop right in too.
Mr. Lime
Quote from: moid on January 02, 2025, 05:56:47 PMHello Mr Lime
I found the following images on an old hard drive - I'm not sure if they are all the images that were in the thread, but the schematic looks like the whole thing?
Hope that's what you are looking for!
Thank you very much, yes that was exactly what I was looking for!  :)
