Active Panny....Wah???!!!!
Started by Matthew Sanford, December 16, 2024, 02:12:29 PM
Matthew Sanford
In reference to this thread's stuff.
So, I'll get to phase on it later, but for an inverted thing a bit tremelo I made it a 4 in, 4 out thing. Started taping LDRs to LEDs, 4 really so I call it lDr. LED IV, and then I made two and created conjoined twins!
Among other things, thinking on these variable resistors in series, why not put a cap to ground at the end as an option to make them low pass filters? So I'm going to do that, still building, but a switch for each for choice. I'll have inverted LDRs, 2 to each out, so one should go down as the other goes up.
Using the 20k trimpot I can increase the voltage, though it reduces the range as it increases it, but not a bad thing necessarily. With it set reasonably to my mind (trim around 13k), testing one LDR shows range of about 12k to 706k, so I thought on 1n, 10n (ridiculous), maybe 2n, but I'm thinking a 3n3, should make it 68Hz-4100Hz about, so C2# on low through full range of a piano. Do you think that is a good setting? Maybe I should just put pin sockets for each so I can swap them out on a pedal when changing the trimpot value...or shoot, later a knob to choose between different values...or maybe start with a baby and switches to add ones in parallel...
So the world is wide open! I'm going to try it with 3n3 and get sounds for you though, hopefully this week.
"The only knowledge is knowing you know nothing" - that Sew Crates guy
Controlled Chaos Fx
" I will say no more "
Matthew Sanford
Nearly done with this thing. I put Jack's FET buffers at each input and output, so 8 of these
I used the taps on the jacks to bring unused ones signals through 1ks to other jacks, 2&3 to 1, &4 to 2. Also switches to cap->ground for variable LPFs prior to output FET.
Block diagram
And Panny like this
With one in one out it's essentially a tremolo, but at a very fast rate it gets resonant I guess with some low volume odd pitches, not sure why...
Right now for the LPF 1n was nothing, 101n (parallel tack on) was eh (done on 1 & 2), then 2u2 tacked on 3 & 4 added a whole new depth. I realized I have a 3 pole (4->2->1) and 2 pole (3->1) on the output, how should I cap them? Shelf with same or various poles?
Controlled Chaos Fx
