PCB question
Started by O'malley's Alley, November 27, 2003, 05:13:27 AM
O'malley's Alley
How exactly do you design a PCB based off of a schematic?
HCFX - Vamp_Hunter_D
GuitarGeek - mancubus22
Mike Burgundy
This is not an exact science, and not easily explained online.
RG's book is a very good resource - buy it, it's worth it.
http://www.geofex.com/bookpages/bookblurb.htm
O'malley's Alley
thing is, I dont really want to produce my own PCB's, I just want to have a PCB layout of a certain schematic, and then have someone else make it for me.
Marek
That question is THE candidate for a Stompbox FAQ!  :-)
I never got to buying R.G.'s book, altho' everybody says it's a must.  If the time component of my life allows it, I'll sure get me this book. I mean, if eveybody is talking so much about it - if there is smoke, there must be fire as well... :-)
Anyway... this subject has been discussed zillion times by now:
http://www.diystompboxes.com/sboxforum/viewtopic.php?t=16021&highlight=
Greetings,
MM
The Tone God
Quote from: O'malley's Alleything is, I dont really want to produce my own PCB's, I just want to have a PCB layout of a certain schematic, and then have someone else make it for me.
If building the boards yourself or having someone else build them what you do with the PCB is kind of irrelvant. Your talking about the design of a PCB here. Analog PCB design CANNOT be summed up in one post. Some of what you will learn will come from experience.
The simplified answer is you make the connections showing in the schematic on PCB using traces. Use some common sense as to where you put parts and signal traces. After that is gets complicated.
QuoteThat question is THE candidate for a Stompbox FAQ
We already have a couple of FAQs linked off the menu above plus the archives.
Andrew
