Dr. Quack questions
Started by Bill_F, November 28, 2003, 09:41:38 PM
Bill_F
Just built the Dr. Quack and am having some problems. No Quack at all. The LED coming off of Pin 1 of the Op-amp is not lighting up, should it be? And there is no voltage at all on Q2. Also I am using a J201 for Q1 is that OK?
I have checked and rechecked and can't find anything wrong. Any suggestions guys?
Bill
idlefaction
the light on the output of the envelope detector should light up when you play.
is power getting to the correct pins on the opamp?
Darren
NZ
