NEED HELP PLEASE
Started by Gstring, December 04, 2003, 11:38:45 AM
Gstring
BUILT  GENERAL GUITAR GADJETS 3 KNOB TONEBENDER-CHECKED EVERYTHING OVER AND OVER-PROBLEM CANNOT GET ANY EFFECT- :?  :?  :? I CAN PASS A GUITAR SIGNAL WHEN PLUG IS PULLED 1/2 OUT OF JACK-I USED ALL NEW PARTS-CLEAN SOLDERING JOB-ANYONE HAVE ANY IDEAS? THANKS
B Tremblay
It's possible that the input jack lugs were mixed-up while wiring.
B Tremblay
runoffgroove.com
Samuel
Your jacks are miswired. Recheck wiring to the switch. Currently the signal is traveling on the "ring" connector of the jack, it should be traveling on the "tip" connector. This also probably means the signal is grounding to the box too....
Gstring
THANKS TO ALL WHO RESPONDED-I WILL CHECK AND POST RESULTS
Gstring
:oops:  :oops: YOU GUYS WERE RIGHT ON-TWO WIRES SWITCHED ON INPUT-UNIT WORKS OK-SOUNDS ROUGH-I HAVE SOME OC81D's  COMING FROM ENGLAND I HOPE THAT WILL GIVE IT MORE POOP-Gstring :oops:  :oops:
Samuel
