How do I figure Mili amps??
Started by Mike Nichting, December 18, 2003, 12:27:19 PM
Mike Nichting
Hay all,
how do I figure mA when I'm done with a pedal so that I know what size of adapter to use??
If there is a safe value for the adapter then just tell me how to figure out the total mA usage of a pedal??
thanks
Mike N.
"It's not pollution thats hurting the earth, it's the impurities in the water and air that are doing it".
Quoted from a Vice President Al Gore speech
In many cases this is very small say 30Ma...
 the 300Ma dapters are quite common...theoretically enough current available there to run 10 pedals.
 To check the ckt's current draw use a DMM's leads...
 Plug one side of the battery clip to the battery
 for the other battery connection to clip, connect the DMM leads and read the current draw ... the battery current must flow through the DMM and current measurement can then be taken.
Mike Nichting
Sounds easy enough  :D
Thanks Pete~!!!
Mike N.
